跳转到主内容
加入维修社区 - 创建账户
Kindle Paperwhite 2nd Generation Screen Replacement
你所需要的
    1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: 步骤 1 中的图像 1,1
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      添加评论
    2. Kindle Paperwhite 2nd Generation Screen Replacement: 步骤 2 中的图像 1,2 Kindle Paperwhite 2nd Generation Screen Replacement: 步骤 2 中的图像 2,2
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      询问修复机器人
      添加评论
    3. Kindle Paperwhite 2nd Generation Screen Replacement: 步骤 3 中的图像 1,1
      • Carefully lift and remove the mid-frame.
      询问修复机器人
      添加评论
    4. Kindle Paperwhite 2nd Generation Screen Replacement: 步骤 4 中的图像 1,1
      • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
Tyler Davis
于09/15/16注册
2,007 声望
创作了5篇指南
团队
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G2
4 名成员
创作了31篇指南
3指南评论
My opening tool is orange. Will this still work for me?
FoxRunTime - 回复 分享
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - 回复 分享
Did this work Liam?
Ben Lowdon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 28
过去 30 天: 170
总计 15,616
