跳转到主内容
加入维修社区 - 创建账户
Kindle Paperwhite 2nd Generation Power Button Replacement
你所需要的
    1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      询问修复机器人
      添加评论
    2. Kindle Paperwhite 2nd Generation Power Button Replacement: 步骤 2 中的图像 1,2 Kindle Paperwhite 2nd Generation Power Button Replacement: 步骤 2 中的图像 2,2
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      询问修复机器人
      添加评论
    3. Kindle Paperwhite 2nd Generation Power Button Replacement: 步骤 3 中的图像 1,1
      • Carefully lift and remove the mid-frame.
      询问修复机器人
      添加评论
    4. Kindle Paperwhite 2nd Generation Power Button Replacement: 步骤 4 中的图像 1,2 Kindle Paperwhite 2nd Generation Power Button Replacement: 步骤 4 中的图像 2,2
      • Remove the power button carefully using a blue plastic opening tool, and replace with a functional unit.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Tyler Davis
于09/15/16注册
2,007 声望
创作了5篇指南
团队
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G2
4 名成员
创作了31篇指南
5指南评论
I have problems with my power button and this is very nice presentation, but I would like to know whether this button is an integral part of the back cover or can be purchased separately and, of course, where it can be purchased.
Thank you for answer and best regards,
Bojan
Bojan Briški - 回复 分享
Seconding this: where exactly can I purchase the button?
Oren Leifer - 回复 分享
Same for me…..where can I buy this button?
Rob Hoenstok - 回复 分享
The power button must be part of an assembly that attaches to the main board in order for it to function. Where can I buy this assembly and not just the plastic button itself?
Roger Joseph
Roger joseph - 回复 分享
This information is not useful unless the author tells us where to buy the power buttin.
Calvin Jordan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 123
总计 6,343
