跳转到主内容
加入维修社区 - 创建账户
Kindle Paperwhite 2nd Generation Motherboard Replacement
你所需要的
    1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
      • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
      添加评论
    2. Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 2 中的图像 1,2 Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 2 中的图像 2,2
      • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      添加评论
    3. Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 3 中的图像 1,1
      • Carefully remove the mid-frame from the back cover.
      询问修复机器人
      添加评论
    4. Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 4 中的图像 1,2 Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 4 中的图像 2,2
      • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
      询问修复机器人
      添加评论
    5. Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 5 中的图像 1,1
      • Carefully lift the battery and remove it from the device.
      询问修复机器人
      添加评论
    1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
      • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
      • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
      询问修复机器人
      添加评论
    2. Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 7 中的图像 1,2 Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 7 中的图像 2,2
      • Gently disconnect the zif connectors.
      • Some of these connectors are very thin and fragile, handle with care!
      添加评论
    3. Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 8 中的图像 1,3 Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 8 中的图像 2,3 Kindle Paperwhite 2nd Generation Motherboard Replacement: 步骤 8 中的图像 3,3
      • Gently remove the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Tyler Davis
于09/15/16注册
2,007 声望
创作了5篇指南
团队
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G2
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 61
总计 4,843
