此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
拆卸平板电脑时,通常需要轻轻撬开中框。在拆卸的前几个步骤中,请务必小心操作,不要弄丢螺丝!Kindle Paperwhite 是一款结构稳固的平板电脑,只需几个组件即可拆解。本指南将通过短短五个步骤,向你展示如何更换故障电池。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
35等其他人完成本指南。
7指南评论
Do you have a source for the battery itself? Thank you.
I’ve done this on two different Kindles with the same result: dead kindle. No matter how long it stays on the charger, the light stays amber. Screen will not change. Hard reset seems to do nothing; the light flashes, but no change. One Paperwhite even got a new motherboard. This is crazy! Is it possible to fix one, do I have to just buy another!?
Adam Britt - 回复 分享
I'm probably 7 years too late but this was the case with one I got from Goodwill and plugging it into a higher amperage charger (2.4A) seemed to do the trick. When you plug it in it charges until there is enough power for it to boot up and when that happens it ends up draining the little bit that was there so it just gets stuck in a loop. You just have to give it more power to work with.
Ellis Bowser - 回复 分享
Hi Adam,
I have the same issue, the light is orange but the Kindle won’t turn on. I ordered the battery at www.batteryupgrade.com. But they have some misleading info on their website so they sent me the wrong battery even if it states that it supports Kindle Paperwhite 2012. Check the connections on original and on the new battery. In my case the battery looks the same, but the connections doesn’t. Now I’m waiting for the new one …
Regards.
Did replacement of battery help you to resolve problem?
behemothkat - 回复 分享
