跳转到主内容
加入维修社区 - 创建账户
Kindle Fire HD 6 Battery Replacement
你所需要的
  1. Kindle Fire HD 6 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
    添加评论
  2. Kindle Fire HD 6 Battery Replacement: 步骤 2 中的图像 1,2 Kindle Fire HD 6 Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully separate the back panel from the rest of the device internals.
    询问修复机器人
    添加评论
  3. Kindle Fire HD 6 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    iOpener
    $14.95
    • Gently pry the battery free from the adhesive holding it in place.
    • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
    • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
    • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
    询问修复机器人
    添加评论
  4. Kindle Fire HD 6 Battery Replacement: 步骤 4 中的图像 1,2 Kindle Fire HD 6 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
    • Remove the battery.
    添加评论
结论
取消:我没有完成这个指南。
18等其他人完成本指南。
团队
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G4
4 名成员
创作了12篇指南
2指南评论
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
terry pils - 回复 分享
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
Sean Collins - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 17
过去 30 天: 90
总计 9,568
