跳转到主内容
加入维修社区 - 创建账户
Kindle 2 Screen Replacement
你所需要的
    1. Kindle 2 Screen Replacement, Battery: 步骤 1 中的图像 1,3 Kindle 2 Screen Replacement, Battery: 步骤 1 中的图像 2,3 Kindle 2 Screen Replacement, Battery: 步骤 1 中的图像 3,3
      • Lay the Kindle face down on a soft cloth to protect its screen.
      • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
      • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
      • Slide the gray plastic top piece away from the Kindle's metal casing.
      • Once the gray plastic top piece is detached from the metal back cover, remove it.
      添加评论
    2. Kindle 2 Screen Replacement: 步骤 2 中的图像 1,2 Kindle 2 Screen Replacement: 步骤 2 中的图像 2,2
      • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
      询问修复机器人
      添加评论
    3. Kindle 2 Screen Replacement: 步骤 3 中的图像 1,2 Kindle 2 Screen Replacement: 步骤 3 中的图像 2,2
      • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
      • Remove the metal casing.
      • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
      询问修复机器人
      添加评论
    4. Kindle 2 Screen Replacement: 步骤 4 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
      • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
      询问修复机器人
      添加评论
    5. Kindle 2 Screen Replacement: 步骤 5 中的图像 1,2 Kindle 2 Screen Replacement: 步骤 5 中的图像 2,2
      • Pry upward under the black tab with the spudger to dislodge the battery.
      • Use your fingers to lift the battery out of the device.
      询问修复机器人
      添加评论
    1. Kindle 2 Screen Replacement, Wireless Card: 步骤 6 中的图像 1,1
      • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
      • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
      添加评论
    2. Kindle 2 Screen Replacement: 步骤 7 中的图像 1,1
      • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
      添加评论
    3. Kindle 2 Screen Replacement: 步骤 8 中的图像 1,2 Kindle 2 Screen Replacement: 步骤 8 中的图像 2,2
      • Use your fingers to lift the left end of the wireless card.
      • Pull the card out of the slot.
      询问修复机器人
      添加评论
    1. Kindle 2 Screen Replacement, Motherboard: 步骤 9 中的图像 1,2 Kindle 2 Screen Replacement, Motherboard: 步骤 9 中的图像 2,2
      • Remove 16 screws from the midframe.
      添加评论
    2. Kindle 2 Screen Replacement: 步骤 10 中的图像 1,3 Kindle 2 Screen Replacement: 步骤 10 中的图像 2,3 Kindle 2 Screen Replacement: 步骤 10 中的图像 3,3
      • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
      • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
      询问修复机器人
      添加评论
    3. Kindle 2 Screen Replacement: 步骤 11 中的图像 1,3 Kindle 2 Screen Replacement: 步骤 11 中的图像 2,3 Kindle 2 Screen Replacement: 步骤 11 中的图像 3,3
      在这个步骤中使用的工具:
      • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
      • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
      询问修复机器人
      添加评论
    4. Kindle 2 Screen Replacement: 步骤 12 中的图像 1,1
      • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
      询问修复机器人
      添加评论
    5. Kindle 2 Screen Replacement: 步骤 13 中的图像 1,2 Kindle 2 Screen Replacement: 步骤 13 中的图像 2,2
      • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
      • Repeat Step 10.
      询问修复机器人
      添加评论
    6. Kindle 2 Screen Replacement: 步骤 14 中的图像 1,1
      • Push your finger down on the last plastic ribbon.
      • Slide your finger away from the connector to remove the last ribbon.
      添加评论
    7. Kindle 2 Screen Replacement: 步骤 15 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
      询问修复机器人
      添加评论
    8. Kindle 2 Screen Replacement: 步骤 16 中的图像 1,1
      • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
      添加评论
    1. Kindle 2 Screen Replacement, Screen: 步骤 17 中的图像 1,1
      • Flip the motherboard over so the screen is facing up.
      • Using your fingers, gently pull off the plastic header bar located at the top of the screen attached to the motherboard.
      询问修复机器人
      添加评论
    2. Kindle 2 Screen Replacement: 步骤 18 中的图像 1,3 Kindle 2 Screen Replacement: 步骤 18 中的图像 2,3 Kindle 2 Screen Replacement: 步骤 18 中的图像 3,3
      • The screen is attached to the motherboard with double sided tape.
      • Pry underneath all four sides of the device with the plastic opening tool to remove the screen from the motherboard.
      添加评论
结论
取消:我没有完成这个指南。
25等其他人完成本指南。
Dayna Scott
于04/16/13注册
985 声望
创作了5篇指南
团队
Cal Poly, Team 12-32, Amido Spring 2013 Cal Poly, Team 12-32, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G32
4 名成员
创作了20篇指南
7指南评论
Great guide!
My replacement screen came with a spudger like the one shown, but it was pretty mangled by the time I got the back off. I had much better luck with another spudger shaped like a guitar pick.
Yeah, the step to remove the inner plastic protector is missing. It is pretty obvious that it needs to happen, but it would be good to include in the guide.
The ribbon for the screen needs to be pushed in further than the other ribbons, and took a bit of wiggling. FYI for others attempting this!
Hannah - 回复 分享
I followed this guide, but the screen is still on the "Amazon Kindle" screen that was on the replacement when it came in the mail. I opened it to ensure the ribbons are all in place. It's fully charged (green light) and the computer can see it as a hard drive. Calibre can also see all the books are still in place. Any ideas what connection I need to recheck to get the replacement screen working? I'd love to get my old Kindle 2 back in business!
tanderson92 - 回复 分享
Answering my own question in case it helps anyone. It turns out the ribbon for the screen (the last one removed in Step 14) wasn't far enough in the connector. I was trying it with the line about even with the "39" on the board, which wasn't far enough. After the eBay seller kindly gave me some tips, I was able to manhandle the ribbon closer to the connector, and now the screen works great!
tanderson92 - 回复 分享
Where can I get one of those replacement screens?
Andie - 回复 分享
In order to be pre-prepared, (I'm pretty sure the double-sided tape holding the screen to the motherboard will need replacement after years of service) is the tape of the fairly thick foam variety or the much thinner plastic ribbon style?
Richard Herndon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 67
总计 24,240
