跳转到主内容
加入维修社区 - 创建账户
Kindle 2 Battery Replacement
你所需要的
    1. Kindle 2 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Kindle 2 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Kindle 2 Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Lay the Kindle face down on a soft cloth to protect its screen.
      • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
      • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
      • Slide the gray plastic top piece away from the Kindle's metal casing.
      • Once the gray plastic top piece is detached from the metal back cover, remove it.
      添加评论
    2. Kindle 2 Battery Replacement: 步骤 2 中的图像 1,2 Kindle 2 Battery Replacement: 步骤 2 中的图像 2,2
      • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
      询问修复机器人
      添加评论
    3. Kindle 2 Battery Replacement: 步骤 3 中的图像 1,2 Kindle 2 Battery Replacement: 步骤 3 中的图像 2,2
      • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
      • Remove the metal casing.
      • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
      询问修复机器人
      添加评论
    4. Kindle 2 Battery Replacement: 步骤 4 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
      • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
      询问修复机器人
      添加评论
    5. Kindle 2 Battery Replacement: 步骤 5 中的图像 1,2 Kindle 2 Battery Replacement: 步骤 5 中的图像 2,2
      • Pry upward under the black tab with the spudger to dislodge the battery.
      • Use your fingers to lift the battery out of the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
42等其他人完成本指南。
团队
Cal Poly, Team 12-32, Amido Spring 2013 Cal Poly, Team 12-32, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G32
4 名成员
创作了20篇指南
9指南评论
I followed this guide, without changes, and was able to successfully swap a battery on a Kindle DX. The DX is essentially a Kindle 2 with a larger screen.
Eric - 回复 分享
Thanks, easy and went well!
Maybe you need a thinner spudger, TH?
Laz - 回复 分享
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
stevenwaegenaer - 回复 分享
Easiest replacement I've done. Thanks!
shockwav - 回复 分享
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
Charles Kennedy - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 41
过去 30 天: 206
总计 41,903
