跳转到主内容
加入维修社区 - 创建账户
Keyboard Keys Replacement Guide
你所需要的
    1. Keyboard Keys Replacement Guide, Keyboard Keys: 步骤 1 中的图像 1,3 Keyboard Keys Replacement Guide, Keyboard Keys: 步骤 1 中的图像 2,3 Keyboard Keys Replacement Guide, Keyboard Keys: 步骤 1 中的图像 3,3
      • Before placing, check that the key is properly orientated. The letter side should be face up.
      • Place the missing key onto the keyboard in the desired orientation. Once aligned, press firmly until the key snaps into place. This will not require large amounts of force. If it does not snap in, realign the key and try again.
      询问修复机器人
      添加评论
    2. Keyboard Keys Replacement Guide: 步骤 2 中的图像 1,1
      • Large rectangular keys need to be attached to the small metal bar to be attached properly. There are two ways to do this.
      询问修复机器人
      添加评论
    3. Keyboard Keys Replacement Guide: 步骤 3 中的图像 1,2 Keyboard Keys Replacement Guide: 步骤 3 中的图像 2,2
      • Before installing, the plastic receivers on the on the bottom of key need to be lined up properly with the metal pins.
      • Option one is to line up the receivers with the metal bar from step 2 and apply pressure to attach.
      询问修复机器人
      添加评论
    4. Keyboard Keys Replacement Guide: 步骤 4 中的图像 1,3 Keyboard Keys Replacement Guide: 步骤 4 中的图像 2,3 Keyboard Keys Replacement Guide: 步骤 4 中的图像 3,3
      • Option two is to be used if the key cannot be attached without removing the metal bar.
      • Pull the metal bar gently from one side to unseat it from the keyboard and allow it to be removed.
      • Attach the metal bar to the receivers on the back of the key.
      • Seat the metal bar into the hole on one side, and then the other. Then press firmly to attach the key.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Steven Park
于03/09/16注册
420 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-5, Catania Spring 2016 UMass Dartmouth, Team 7-5, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G5
3 名成员
创作了30篇指南
1指南评论
Great guide! One thing worth adding: laptop keys actually come in three retainer clip types — standard scissor (most common, two interlocking plastic arms), butterfly/inverted V (older MacBooks, very fragile), and snap-on single-piece clips (found on some Lenovo ThinkPads). The rubber cup underneath is equally important — if it's flattened or torn, the key will feel mushy even after reinstalling the cap. When diagnosing a wobbly key, check whether the clip is bent or cracked at the hinge point before ordering a replacement, since that's the component that fails most often.
Jeff Horton - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 52
过去 30 天: 217
总计 14,910
