简介
Use this guide to replace the Limit Switch that tells the Keurig that the K-Cup section is closed.
你所需要的
Remove the switch by cuting the two connecting wires. Reconnect a replacement switch using this guide to join wires with solder, or using this guide to solder connections, or by using any other technique to connect wires.
即将完成!
结论
另外一个人完成了本指南。
