跳转到主内容
Kenmore 400 Washer clutch band Replacement
你所需要的
  1. Kenmore 400 Washer clutch band Replacement, Clutch band: 步骤 1 中的图像 1,3 Kenmore 400 Washer clutch band Replacement, Clutch band: 步骤 1 中的图像 2,3 Kenmore 400 Washer clutch band Replacement, Clutch band: 步骤 1 中的图像 3,3
    • Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly.
    • Open the lid
    • Remove cap from the agitator by using a flat tip screwdriver or similar.
  2. Kenmore 400 Washer clutch band Replacement: 步骤 2 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 2 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 2 中的图像 3,3
    • With the cap removed, a 7/16 hex bolt becomes visible.
    • Use a socket wrench with 4 inch extension to remove the bolt.
    • The agitator bolt measures 5/16 X 1 inches, 24 thread size
  3. Kenmore 400 Washer clutch band Replacement: 步骤 3 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 3 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 3 中的图像 3,3
    • With the bolt removed, pull the agitator of the shaft.
    • View of the drum with agitator removed
    • For ease of working on the bottom parts, lay the washer on its side.
  4. Kenmore 400 Washer clutch band Replacement: 步骤 4 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 4 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 4 中的图像 3,3
    • Main parts of the assembly include
    • Drain pump
    • Motor
    • Transmission
    • This is a direct drive model. No belts but a motor coupler connects the motor to transmission. Check for any cracks etc.
    • Remove the wiring harness from the motor
  5. Kenmore 400 Washer clutch band Replacement: 步骤 5 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 5 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 5 中的图像 3,3
    • Remove the wiring harness from the clip on the transmission
    • Drain lines from the drum and drain hose are connected to the pump with spring clamps.
    • Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
  6. Kenmore 400 Washer clutch band Replacement: 步骤 6 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 6 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 6 中的图像 3,3
    • Pull the drain hose of the pump
    • Remove the tub-to-pump hose the same way
    • Remove the three 1/2inch bolts.
  7. Kenmore 400 Washer clutch band Replacement: 步骤 7 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 7 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 7 中的图像 3,3
    • Here are the three bolts. They are 5/16 by 11/16 with a 1/2 inch hex head.
    • With the three bolts removed, pull the complete assembly out of the drum
    • With the assembly removed, the clutch is now completely visible.
  8. Kenmore 400 Washer clutch band Replacement: 步骤 8 中的图像 1,3 Kenmore 400 Washer clutch band Replacement: 步骤 8 中的图像 2,3 Kenmore 400 Washer clutch band Replacement: 步骤 8 中的图像 3,3
    • It is not necessary to replace the whole clutch. For this repair only the clutch band needs to be replaced
    • Using a pair of pliers to compress the spring will loosen the clutch band.
    • Lift the clutch band out of the clutch housing
    • Clutch band removed. Replace with model specific part.
结论
11等其他人完成本指南。
oldturkey03
于09/29/10注册
783,931 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了555篇指南
15条评论
Would this repair fix a 80 series Kenmore washer with same problem of no high-speed spinning
Larry Simonetta - 回复
Possibly but it depends on what is going on with it. This one spun just sluggish and not „forcefull“ enough. It pretty much stopped spinning with a full load because of the weak clutch
oldturkey03 -
How much do it cost to repair it
Ralph Lingelbach - 回复
The complete repair kit was somewhere between USD $30-$40
oldturkey03 -
I'm a jack of all if I can get it out I can rebuild it im a maintenance man at chicken proscenium plant we got to fixs all of it
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 37
过去 30 天: 245
总计 29,981
