跳转到主内容
加入维修社区 - 创建账户
Kayak Handle Replacement
你所需要的
    1. Kayak Handle Replacement, Handle: 步骤 1 中的图像 1,1
      • Detach the handle and paracord strap from the kayak.
      询问修复机器人
      添加评论
    2. Kayak Handle Replacement: 步骤 2 中的图像 1,3 Kayak Handle Replacement: 步骤 2 中的图像 2,3 Kayak Handle Replacement: 步骤 2 中的图像 3,3
      • Insert the screwdriver into the head of the bolt on the bottom side of the handle.
      • Apply pressure to the bottom of the handle.
      • Remove the top part of the handle by using the screwdriver to pop it out.
      • Caution: Do not let the hardware fall into the hull, as it may slide into unreachable areas of the bow or stern.
      询问修复机器人
      添加评论
    3. Kayak Handle Replacement: 步骤 3 中的图像 1,2 Kayak Handle Replacement: 步骤 3 中的图像 2,2
      • Pull the paracord out of the handle so they are separate from each other.
      询问修复机器人
      添加评论
    4. Kayak Handle Replacement: 步骤 4 中的图像 1,3 Kayak Handle Replacement: 步骤 4 中的图像 2,3 Kayak Handle Replacement: 步骤 4 中的图像 3,3
      • Cut the end of the paracord using your knife or a pair of scissors.
      • Insert the paracord into the bottom side of the handle through the small hole.
      • Pull it through so each side of the paracord is evenly inserted.
      询问修复机器人
      添加评论
    5. Kayak Handle Replacement: 步骤 5 中的图像 1,2 Kayak Handle Replacement: 步骤 5 中的图像 2,2
      • Tie a knot with the paracord using both ends of the already inserted paracord.
      • Pull it tight and be sure that the knot is as close to the edge of the paracord as possible.
      • Cut the excess paracord at the end of the knot if there is any.
      询问修复机器人
      添加评论
    6. Kayak Handle Replacement: 步骤 6 中的图像 1,3 Kayak Handle Replacement: 步骤 6 中的图像 2,3 Kayak Handle Replacement: 步骤 6 中的图像 3,3
      • Pull the paracord through the handle so that the knot is now inside the handle.
      • Add the cover of the handle back onto the top. Secure it down tightly.
      询问修复机器人
      添加评论
    7. Kayak Handle Replacement: 步骤 7 中的图像 1,3 Kayak Handle Replacement: 步骤 7 中的图像 2,3 Kayak Handle Replacement: 步骤 7 中的图像 3,3
      • Locate the metal bar on the kayak and place the looped end of the new handle underneath it.
      • Pull the paracord all the way through until the handle stops it.
      • Loop the paracord over the plastic handle.
      • Pull the handle tightly to secure it in place.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 247
