跳转到主内容
加入维修社区 - 创建账户
K. Preflight Checklist-Motion
    1. K. Preflight Checklist-Motion, Homing X&Y: 步骤 1 中的图像 1,2 K. Preflight Checklist-Motion, Homing X&Y: 步骤 1 中的图像 2,2
      • Press Home X. The hot end should move to the left towards the end stop. It will bump the end stop move to the right a few mm, than back left to the end stop and stop.
      • Measure the distance from the edge of the Top X Mount to the edge of the bearing block. Jog the hot end +10mm and re-measure. It should be 10mm larger.
      • Press Home Y. The hot end should move to the back towards the end stop. It will bump the end stop move to forward a few mm, than to the back to the end stop and stop.
      • Measure the distance from the edge of the rear corner to the edge of the bearing block. Jog the hot end -10mm and re-measure. It should be 10mm larger.
      询问修复机器人
      添加评论
    2. K. Preflight Checklist-Motion, Homing Z: 步骤 2 中的图像 1,2 K. Preflight Checklist-Motion, Homing Z: 步骤 2 中的图像 2,2
      • During bed leveling, you want the probe position to be at the center of the bed, not the nozzle. Once you have your X and Y coordinates calculated press Home Z
      • The probe(not the nozzle) will move to the center of the bed, Deploy the probe, raise the bed, stop once the probe is triggered, and lower the bed.
      • If your probe is slightly off center we need to correct it. Manually jog the hotend so the probe is in the center of the bed. Note the coordinates
      • Take the coordinates off the web page and replace them in homez.g and homeall.g
      • G1 X178.75 Y155.2 F10000 ; go to first probe point
      询问修复机器人
      添加评论
    3. K. Preflight Checklist-Motion, Motion: 步骤 3 中的图像 1,1
      • Manually jog the hot end
      • When you jog +X it will move to the right
      • When you jog +Y it will move towards the back.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
David Husolo
于06/16/21注册
9,382 声望
创作了33篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 45
总计 1,414
