跳转到主内容
加入维修社区 - 创建账户
Jazz UltraTab C855 Battery Replacement
你所需要的
    1. Jazz UltraTab C855 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
      询问修复机器人
      添加评论
    2. Jazz UltraTab C855 Battery Replacement: 步骤 2 中的图像 1,1
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      询问修复机器人
      添加评论
    1. Jazz UltraTab C855 Battery Replacement, Battery: 步骤 3 中的图像 1,1
      • Remove the yellow tape from the sides of the battery, and the surrounding components.
      询问修复机器人
      添加评论
    2. Jazz UltraTab C855 Battery Replacement: 步骤 4 中的图像 1,1
      • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
      • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
      询问修复机器人
      添加评论
    3. Jazz UltraTab C855 Battery Replacement: 步骤 5 中的图像 1,1
      • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
      • The battery is secured to the device with adhesive.
      • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      询问修复机器人
      添加评论
    4. Jazz UltraTab C855 Battery Replacement: 步骤 6 中的图像 1,1
      • Use a two sided adhesive to secure the new battery in place.
      • Solder or crimp the wires back together to reattach to the motherboard.
      • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Cory Hodge
于09/14/15注册
201 声望
创作了2篇指南
团队
IUPUI, Team 1-3, Baechle Fall 2015 IUPUI, Team 1-3, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S1G3
5 名成员
创作了27篇指南
1指南评论
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 799
