跳转到主内容
加入维修社区 - 创建账户
Jazz Digi-Stix JDC11 Case Replacement
你所需要的
    1. Jazz Digi-Stix JDC11 Case Replacement, Battery: 步骤 1 中的图像 1,2 Jazz Digi-Stix JDC11 Case Replacement, Battery: 步骤 1 中的图像 2,2
      • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
      询问修复机器人
      添加评论
    2. Jazz Digi-Stix JDC11 Case Replacement: 步骤 2 中的图像 1,1
      • Tilt device so that batteries slide out.
      询问修复机器人
      添加评论
    1. Jazz Digi-Stix JDC11 Case Replacement, Capture Button: 步骤 3 中的图像 1,3 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: 步骤 3 中的图像 2,3 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: 步骤 3 中的图像 3,3
      • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
      • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
      询问修复机器人
      添加评论
    2. Jazz Digi-Stix JDC11 Case Replacement: 步骤 4 中的图像 1,3 Jazz Digi-Stix JDC11 Case Replacement: 步骤 4 中的图像 2,3 Jazz Digi-Stix JDC11 Case Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
      • Gently seperate the two halves of the device.
      • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
      • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
      询问修复机器人
      添加评论
    3. Jazz Digi-Stix JDC11 Case Replacement: 步骤 5 中的图像 1,1
      • Carefully separate the grey side bar from the case and set it aside.
      询问修复机器人
      添加评论
    4. Jazz Digi-Stix JDC11 Case Replacement: 步骤 6 中的图像 1,1
      • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
      询问修复机器人
      添加评论
    1. Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: 步骤 7 中的图像 1,3 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: 步骤 7 中的图像 2,3 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: 步骤 7 中的图像 3,3
      • To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
      询问修复机器人
      添加评论
    2. Jazz Digi-Stix JDC11 Case Replacement: 步骤 8 中的图像 1,3 Jazz Digi-Stix JDC11 Case Replacement: 步骤 8 中的图像 2,3 Jazz Digi-Stix JDC11 Case Replacement: 步骤 8 中的图像 3,3
      • Unscrew the three 5.6 mm Phillips #00 screws that connect the battery compartment to the case.
      • Remove the battery compartment from the case of the device.
      询问修复机器人
      添加评论
    1. Jazz Digi-Stix JDC11 Case Replacement, Case: 步骤 9 中的图像 1,2 Jazz Digi-Stix JDC11 Case Replacement, Case: 步骤 9 中的图像 2,2
      • Remove viewer from the top-left corner of the case by gently pulling it away.
      询问修复机器人
      添加评论
    2. Jazz Digi-Stix JDC11 Case Replacement: 步骤 10 中的图像 1,1
      • If the replacement case does not have a wrist strap, remove your device's wrist strap by feeding the plastic tab through the loop cord, and then pulling it all the way through.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Katelyn Fry
于03/11/13注册
1 声望
创作了7篇指南
团队
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S12G3
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 502
