跳转到主内容
加入维修社区 - 创建账户
Jawbone MINI JAMBOX Side Button Assembly Replacement
你所需要的
    1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: 步骤 1 中的图像 1,2 Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: 步骤 1 中的图像 2,2
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      添加评论
    2. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 2 中的图像 1,1
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      询问修复机器人
      添加评论
    3. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 3 中的图像 1,1
      • Slide out the rubber foot located on the bottom of the case.
      询问修复机器人
      添加评论
    4. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 4 中的图像 1,1
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      添加评论
    5. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 5 中的图像 1,3 Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 5 中的图像 2,3 Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 5 中的图像 3,3
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      询问修复机器人
      添加评论
    1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: 步骤 6 中的图像 1,2 Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: 步骤 6 中的图像 2,2
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      询问修复机器人
      添加评论
    2. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 7 中的图像 1,1
      • Using the standard metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      询问修复机器人
      添加评论
    3. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 8 中的图像 1,3 Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 8 中的图像 2,3 Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 8 中的图像 3,3
      在这个步骤中使用的工具:
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF or "zero insertion force" ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      询问修复机器人
      添加评论
    4. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 9 中的图像 1,1
      • Using the spudger, push the button in and create a small gap between the outside structure and the button.
      询问修复机器人
      添加评论
    5. Jawbone MINI JAMBOX Side Button Assembly Replacement: 步骤 10 中的图像 1,1
      • Using a computer duster, blow any contaminants out from the button junction.
      • Using a q-tip and cleaner, wipe off any stickiness from the buttons, ensuring to prevent excessive moisture.
      • Alternate Reassembly required, read on.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow steps 1 through 5 in reverse order.
取消:我没有完成这个指南。
团队
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G1
5 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 26
总计 1,198
