跳转到主内容
加入维修社区 - 创建账户
JYX-S55 Battery Replacement
你所需要的
  1. JYX-S55 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
    询问修复机器人
    添加评论
  2. JYX-S55 Battery Replacement: 步骤 2 中的图像 1,1
    • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
    询问修复机器人
    添加评论
  3. JYX-S55 Battery Replacement: 步骤 3 中的图像 1,2 JYX-S55 Battery Replacement: 步骤 3 中的图像 2,2
    • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
    询问修复机器人
    添加评论
  4. JYX-S55 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a nylon spudger to pry the battery free from the glue.
    • It is important to note do NOT use heat or sharp objects, as the lithium-ion battery is flammable and could potentially explode.
    添加评论
  5. JYX-S55 Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the red and black wires from the battery.
    • Remove the battery from the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sarah Iceman
于02/24/23注册
502 声望
创作了2篇指南
团队
Marist, Team 1-5, Chaterdon Spring 2023 Marist, Team 1-5, Chaterdon Spring 2023 的会员
MARS-CHATERDON-S23S1G5
3 名成员
创作了8篇指南
3指南评论
Hi, thanks for the pictures that really helped. What type of battery is needed? Can you email me at vrhaiza@gmail.com.
Rhaiza Villafranca - 回复 分享
Can you please advise what type of battery would be needed? What if I don't have a nylon spudger? What can I use in exchange?
Jasmine - 回复 分享
I opened the Karaoke machine:
Lithium-ion
Type- Lithium-ion Battery
Capacity: 3.7V/5200mAh
Model:18650C
Charging limited:4.2V
Date: 2022L1
M
DeniseCabral - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 29
过去 30 天: 164
总计 8,259
