跳转到主内容
JUKSTG Computer Mouse LED Replacement LED Light Replacement
你所需要的
  1. JUKSTG Computer Mouse LED Replacement LED Light Replacement, LED Light: 步骤 1 中的图像 1,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement, LED Light: 步骤 1 中的图像 2,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement, LED Light: 步骤 1 中的图像 3,3
    • Use a Phillips screwdriver to remove the 5x10mm screw that secures the upper and lower case.
    • Remove the top cover.
  2. JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 2 中的图像 1,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 2 中的图像 2,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 2 中的图像 3,3
    • Remove the scroll wheel and gently remove the mainboard.
    • Flip over the mainboard to expose the soldered LED connections.
  3. JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 3 中的图像 1,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 3 中的图像 2,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 3 中的图像 3,3
    • Pre-heat a soldering iron and leave it on standby until it reaches at least 350 C (662 F). Prepare a desoldering pump by pushing down on the plunger.
    • Once the soldering iron reaches 350 C, press the tip gently on each side of the old solder and wait for it to melt, one connection at a time.
    • The melting process may either be instantaneous or take a few seconds.
    • Once the solder is melted, quickly cover the melted solder with the tip of the desoldering vacuum and press the button to suck up the molten solder.
    • The removal process should end when there are visible holes where the solder used to be. The old LED light should fall off during this process.
    • CAUTION: Soldering iron is extremely HOT. Always solder in a well-ventilated area or with a running fume extractor.
  4. JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 4 中的图像 1,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 4 中的图像 2,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 4 中的图像 3,3
    • Flip the mainboard upside down and insert the new LED in the same orientation and polarity as the old LED.
    • Flip over the control panel again and ensure the new LED is supported in the holes.
    • A piece of masking tape can be used to hold the LED in place.
    • To ensure the new LED is placed in the correct orientation, determine the polarity. Polarity refers to the electrical current flow between the anode (positive +) and cathode (negative -) terminals. The long leg will most likely be the anode and must be connected as such.
  5. JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 5 中的图像 1,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 5 中的图像 2,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 5 中的图像 3,3
    • Press the iron tip against the right pad and LED lead for 2-3 seconds, then feed enough solder into the joint to encapsulate the lead.
    • The ideal joint will look smooth and concave, like a cartoon volcano.
    • Remove the solder, then remove the iron.
    • Repeat the previous bullets in this step for the other joint.
    • CAUTION: Do not tamper with the solder as it melts, for it will harden almost immediately.
    • Tin the tip of your iron, then power it down and wait for it to fully cool prior storage.
  6. JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 6 中的图像 1,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 6 中的图像 2,3 JUKSTG Computer Mouse LED Replacement LED Light Replacement: 步骤 6 中的图像 3,3
    • The new melted solder does not need to be perfectly round.
    • When putting everything together, ensure that the battery cables are inserted in the slot specifically for them, or the top cover will not fit properly.
结论
Raphael Real
于02/15/24注册
133 声望
撰写一个指南
团队
York University, Team 2-2, Morris Winter 2025 York University, Team 2-2, Morris Winter 2025 的会员
YORK-MORRIS-W25S2G2
4 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 94
