跳转到主内容
加入维修社区 - 创建账户
JD Razor 2000 Handle Bar Replacement
你所需要的
    1. JD Razor 2000 Handle Bar Replacement, Pulling Out the String: 步骤 1 中的图像 1,3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: 步骤 1 中的图像 2,3 JD Razor 2000 Handle Bar Replacement, Pulling Out the String: 步骤 1 中的图像 3,3
      • Firmly hold the handle bar in place.
      • Grab with one hand the black removable tip of the handle bar and pull it out.
      • Pull out the end of the tied string through the removable tip.
      询问修复机器人
      添加评论
    2. JD Razor 2000 Handle Bar Replacement, Untying the Knot: 步骤 2 中的图像 1,2 JD Razor 2000 Handle Bar Replacement, Untying the Knot: 步骤 2 中的图像 2,2
      • Untie the knot at the end of the string.
      • If you let go of the string while its in tension, it may recoil far into the other side of the handle bars. To avoid this, bring the end of the string inward towards the hollow section of the handle bar and then carefully let it go.
      询问修复机器人
      添加评论
    3. JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: 步骤 3 中的图像 1,2 JD Razor 2000 Handle Bar Replacement, Pulling Out the Handlebar: 步骤 3 中的图像 2,2
      • Press down firmly on the golden fastening button located on the handle bar being replaced.
      • While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
      • When re-installing the handlebar (after completion of the guide), you may need a pair of needle-nosed pliers to thread the string back through the handlebar.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Kevin Church
于10/16/14注册
297 声望
创作了2篇指南
团队
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G46
4 名成员
创作了16篇指南
3指南评论
Why is the stretchable string for?
dantotford - 回复 分享
Where can I buy a wider set of click in handlebars?
Scooterdad - 回复 分享
I'm also looking for a JD BUG replacement handlebar, I mean the horizontal parts.
Mon Drianus - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 58
总计 2,984
