简介
The front wheel of the JD Razor 2000 is located directly underneath the handlebar and T-Bar.
你所需要的
Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
Carefully pull apart the bolt and bearing from either side of the wheel.
