简介
The LED light display is located on the inside of the JBL Pulse 3, under the outside casing. It LED light display is lined with LED light strips along the circular base.
你所需要的
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
Pull the LED light display off of the JBL Pulse 3 base.
3等其他人完成本指南。
4指南评论
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - 回复 分享
Where to buy the leds?
mj.viana1993 - 回复 分享
