跳转到主内容
加入维修社区 - 创建账户
JBL Flip 4 Controls Board Replacement
你所需要的
  1. JBL Flip 4 Controls Board Replacement, Controls Board: 步骤 1 中的图像 1,3 JBL Flip 4 Controls Board Replacement, Controls Board: 步骤 1 中的图像 2,3 JBL Flip 4 Controls Board Replacement, Controls Board: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Pull off the cover off with your thumbs.
    询问修复机器人
    添加评论
  2. JBL Flip 4 Controls Board Replacement: 步骤 2 中的图像 1,3 JBL Flip 4 Controls Board Replacement: 步骤 2 中的图像 2,3 JBL Flip 4 Controls Board Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool under the clear rubber cover over the button control board.
    • Pry up the cover using the opening tool.
    • The cover is glued on so it will take some force to pry up.
    询问修复机器人
    添加评论
  3. JBL Flip 4 Controls Board Replacement: 步骤 3 中的图像 1,2 JBL Flip 4 Controls Board Replacement: 步骤 3 中的图像 2,2
    • Pry up the button control board by inserting the metal spudger underneath both sides of the board.
    • Try not to damage the green control board while using the metal tools.
    • The control board is glued down as well, so you will need to use some force.
    询问修复机器人
    添加评论
  4. JBL Flip 4 Controls Board Replacement: 步骤 4 中的图像 1,1
    • Once the board is partially unattached, pull it off using your hands.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
20等其他人完成本指南。
Philip Pang
于10/08/18注册
1,458 声望
创作了4篇指南
团队
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 的会员
CPSU-WHITE-F18S4G3
4 名成员
创作了37篇指南
9指南评论
Where can i buy ,control board for jbl flip 4?
Mihajlo - 回复 分享
I would also be interested in buying a board (but the one at the top of the speaker, whichis holding the On and Off, as well as the JBL Connect button ). Thanks!
JPA - 回复 分享
Does anyone at ifixit know where to get replacement boards?
EAN - 2/28/19
Eric - 回复 分享
Id be interested in JBLmaking a minimally acceptable product
Mary Lea McTurnan - 回复 分享
Where can I buy the ribbon cable?
Randl Manigsaca - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 32
过去 30 天: 159
总计 37,404
