跳转到主内容
加入维修社区 - 创建账户
JBL Clip 4 Battery Replacement
你所需要的
    1. JBL Clip 4 Battery Replacement, Front Grill: 步骤 1 中的图像 1,1
      • Get a tool to pry the front grill off, ideally using one of the iFixit tools. This is required as the front grill is glued onto the device.
      询问修复机器人
      添加评论
    2. JBL Clip 4 Battery Replacement: 步骤 2 中的图像 1,1
      • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
      询问修复机器人
      添加评论
    1. JBL Clip 4 Battery Replacement, Back Housing: 步骤 3 中的图像 1,1
      • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
      询问修复机器人
      添加评论
    2. JBL Clip 4 Battery Replacement: 步骤 4 中的图像 1,1
      • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
      询问修复机器人
      添加评论
    1. JBL Clip 4 Battery Replacement, Battery: 步骤 5 中的图像 1,1
      • The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    2. JBL Clip 4 Battery Replacement: 步骤 6 中的图像 1,1
      • Now all you need to do is pull the battery out of the case its in and you have successfully disconnected the battery from the device.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
Trey Adao
于03/06/26注册
598 声望
创作了6篇指南
团队
UMass Dartmouth, Team 3-4, Shaddix Spring 2026 UMass Dartmouth, Team 3-4, Shaddix Spring 2026 的会员
UMASSD-SHADDIX-S26S3G4
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 56
总计 180
