跳转到主内容
加入维修社区 - 创建账户
JBL Charge 4 Buttons Replacement
你所需要的
  1. JBL Charge 4 Buttons Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    添加评论
  2. JBL Charge 4 Buttons Replacement: 步骤 2 中的图像 1,2 JBL Charge 4 Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    添加评论
  3. JBL Charge 4 Buttons Replacement: 步骤 3 中的图像 1,1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
    询问修复机器人
    添加评论
  4. JBL Charge 4 Buttons Replacement, Passive Bass Radiators: 步骤 4 中的图像 1,2 JBL Charge 4 Buttons Replacement, Passive Bass Radiators: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    添加评论
  5. JBL Charge 4 Buttons Replacement: 步骤 5 中的图像 1,2 JBL Charge 4 Buttons Replacement: 步骤 5 中的图像 2,2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
    添加评论
  6. JBL Charge 4 Buttons Replacement, Buttons: 步骤 6 中的图像 1,3 JBL Charge 4 Buttons Replacement, Buttons: 步骤 6 中的图像 2,3 JBL Charge 4 Buttons Replacement, Buttons: 步骤 6 中的图像 3,3
    • Lift up the tape covering the button control board ZIF connector on the left side of the motherboard.
    • Flip up the black locking flap on the ZIF connector with the tip of the spudger or your fingernail to release the white ribbon cable.
    添加评论
  7. JBL Charge 4 Buttons Replacement: 步骤 7 中的图像 1,2 JBL Charge 4 Buttons Replacement: 步骤 7 中的图像 2,2
    • Flip the speaker over so the buttons are on the top.
    • Using the plastic opening tool, pry up the rubber covering the button control board from the adhesive.
    • Remove the cover and set to the side.
    • By removing the rubber cover and the control board you are breaking adhesives that may result in the speaker no longer being waterproof.
    询问修复机器人
    添加评论
  8. JBL Charge 4 Buttons Replacement: 步骤 8 中的图像 1,3 JBL Charge 4 Buttons Replacement: 步骤 8 中的图像 2,3 JBL Charge 4 Buttons Replacement: 步骤 8 中的图像 3,3
    • Using the plastic opening tool, pry up the button control board from the adhesive.
    • This will require cutting the adhesive surrounding the board.
    • Gently lift off the button control board feeding the ribbon cable through the slot.
    • When installing a new button control board, make sure to clean all the adhesive residue left by the old board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
14等其他人完成本指南。
团队
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 的会员
CPSU-WHITE-W19S1G1
4 名成员
创作了29篇指南
2指南评论
Hi - where can I buy the button control board?
Rahman Sayeed - 回复 分享
How do I boot up JBL CHARGE 4
sashajankovic527 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 178
总计 26,973
