跳转到主内容
加入维修社区 - 创建账户
JBL Charge 4 Battery Replacement
你所需要的
  1. JBL Charge 4 Battery Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    添加评论
  2. JBL Charge 4 Battery Replacement: 步骤 2 中的图像 1,2 JBL Charge 4 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    添加评论
  3. JBL Charge 4 Battery Replacement: 步骤 3 中的图像 1,1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
    询问修复机器人
    添加评论
  4. JBL Charge 4 Battery Replacement, Passive Bass Radiators: 步骤 4 中的图像 1,2 JBL Charge 4 Battery Replacement, Passive Bass Radiators: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    添加评论
  5. JBL Charge 4 Battery Replacement: 步骤 5 中的图像 1,2 JBL Charge 4 Battery Replacement: 步骤 5 中的图像 2,2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
    添加评论
  6. JBL Charge 4 Battery Replacement, Battery: 步骤 6 中的图像 1,2 JBL Charge 4 Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
    询问修复机器人
    添加评论
  7. JBL Charge 4 Battery Replacement: 步骤 7 中的图像 1,1
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
    添加评论
  8. JBL Charge 4 Battery Replacement: 步骤 8 中的图像 1,3 JBL Charge 4 Battery Replacement: 步骤 8 中的图像 2,3 JBL Charge 4 Battery Replacement: 步骤 8 中的图像 3,3
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
    询问修复机器人
    添加评论
  9. JBL Charge 4 Battery Replacement: 步骤 9 中的图像 1,1
    • Lift up the battery cover.
    询问修复机器人
    添加评论
  10. JBL Charge 4 Battery Replacement: 步骤 10 中的图像 1,3 JBL Charge 4 Battery Replacement: 步骤 10 中的图像 2,3 JBL Charge 4 Battery Replacement: 步骤 10 中的图像 3,3
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
    添加评论
  11. JBL Charge 4 Battery Replacement: 步骤 11 中的图像 1,2 JBL Charge 4 Battery Replacement: 步骤 11 中的图像 2,2
    • Remove the battery from the battery socket by gently pulling on it.
    询问修复机器人
    添加评论
  12. JBL Charge 4 Battery Replacement: 步骤 12 中的图像 1,3 JBL Charge 4 Battery Replacement: 步骤 12 中的图像 2,3 JBL Charge 4 Battery Replacement: 步骤 12 中的图像 3,3
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
    添加评论
结论
取消:我没有完成这个指南。
31等其他人完成本指南。
Sydney Seto
于01/24/19注册
990 声望
撰写一个指南
团队
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 的会员
CPSU-WHITE-W19S1G1
4 名成员
创作了29篇指南
18指南评论
Where do you buy a battery for a jbl Charge 4 ??
Matt hempel - 回复 分享
Probably just cut open the blue foil around the batteries and replace them by re-soldering the electronics onto new 18650 batteries.
correct me if I’m wrong here.
Brendon Reijnders - 回复 分享
If you know how to handle them and have experience with soldering them that's a yes if not those batteries are really dangerous if you don't know how to do it correctly.
Hart80 - 回复 分享
Where in the !&&* do i get a battery for a bluetooth speaker. What happened to the jbl charge 4 that it even goes out???
Shani Sanders - 回复 分享
My JBL charge 4 battery dead too. 9nly uses it for three months
osborne buhere - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 31
过去 7 天: 168
过去 30 天: 960
总计 86,177
