跳转到主内容
加入维修社区 - 创建账户
JBL Charge 3 Button Replacement
你所需要的
  1. JBL Charge 3 Button Replacement, Front Cover: 步骤 1 中的图像 1,3 JBL Charge 3 Button Replacement, Front Cover: 步骤 1 中的图像 2,3 JBL Charge 3 Button Replacement, Front Cover: 步骤 1 中的图像 3,3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    添加评论
  2. JBL Charge 3 Button Replacement: 步骤 2 中的图像 1,1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    添加评论
  3. JBL Charge 3 Button Replacement, Button: 步骤 3 中的图像 1,2 JBL Charge 3 Button Replacement, Button: 步骤 3 中的图像 2,2
    • Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
    • Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
    询问修复机器人
    添加评论
  4. JBL Charge 3 Button Replacement: 步骤 4 中的图像 1,2 JBL Charge 3 Button Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Flip open the top flap on the ZIF connector.
    • Gently pull out the ZIF connector cable with tweezers.
    添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Sunmin Yoon
于10/30/18注册
2,096 声望
创作了2篇指南
团队
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 的会员
CPSU-WHITE-F18S13G1
3 名成员
创作了30篇指南
4指南评论
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - 回复 分享
Where do i buy new buttons?
Thomas Bjerregaard - 回复 分享
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - 回复 分享
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 153
总计 28,625
