跳转到主内容
加入维修社区 - 创建账户
J. Preflight Checklist-Endstops
    1. J. Preflight Checklist-Endstops, End Stops: 步骤 1 中的图像 1,2 J. Preflight Checklist-Endstops, End Stops: 步骤 1 中的图像 2,2
      • Make sure none of the end stops are triggered.
      • Manually trigger the X end stop and re enter M119. It should return a status of "at min stop" for X and Y should say "not stopped"
      • Manually trigger the Y end stop and re enter M119. It should return a status of "at max stop" for Y and X should say "not stopped"
      询问修复机器人
      添加评论
    2. J. Preflight Checklist-Endstops, BLTouch: 步骤 2 中的图像 1,1
      • You should have a Macros folder for your BLTouch. Select Deploy, the pin should deploy. Select Retract, the pin should retract.
      • If the BLTouch starts blinking at any point normally it's a bad connection check your wiring.
      • Occasionally running the "Alarm Release Pin Up" macro can solve a blinking BLTouch
      询问修复机器人
      添加评论
      • Heat the nozzle to 200c and bed to 60c and wait for the temperatures to stabilize. Remove any filament that is stuck to the nozzle.
      • If you have independent axis leveling configured make sure you run. Home all axis.
      • Jog the nozzle to the center of the bed. If using my github config, move the hotend X-40 so the nozzle is in the center of the bed.
      • Place a piece of paper under the nozzle.
      • A lot of times when calibrating Z offset the bed can't move up high enough because we don't have it configured to allow Z to go past 0. Out of habit when calibrating Z offset I will send G92 Z15 which tells the printer the new Z position is Z15. This will give me more than enough to calibrate the Z offset now.
      • In the console enter
      • M558 P9 C"^zprobe.in"
      • G31 P500 Z1.0
      询问修复机器人
      添加评论
      • Jog the bed up carefully using the Z-.50 and Z-.05 buttons until the nozzle grips the paper
      • Once the nozzle grips the paper send G92 Z0
      • Lower the bed 10mm
      • Move the probe to bed center(same amount as step 3 but move it to the right)
      • Send G30 S-1. This will probe the bed and tell you the offset. Move the bed to Z10 and run G30 S-1 again. Repeat this step a couple of times. When finished move the bed to Z10.
      • Take the average of the Z offset readings from the console and replace your current G31 P500 X-42.45 Y0 Z## in config.g
      • Save and restart your printer
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
David Husolo
于06/16/21注册
9,382 声望
创作了33篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 1,108
