跳转到主内容
加入维修社区 - 创建账户
Ivation IVWPDC20Y Flash Bulb Replacement
你所需要的
    1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: 步骤 1 中的图像 1,1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      询问修复机器人
      添加评论
    2. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 2 中的图像 1,1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      询问修复机器人
      添加评论
    3. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 3 中的图像 1,1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
      询问修复机器人
      添加评论
    4. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 4 中的图像 1,1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      询问修复机器人
      添加评论
    5. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 5 中的图像 1,1
      • Pry off back outer casing using the black spudger or the blue prying tools
      询问修复机器人
      添加评论
    6. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 6 中的图像 1,1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
      询问修复机器人
      添加评论
    7. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 7 中的图像 1,1
      • Gently push out the pins holding the orange tape down using the pointy end of the spudger
      • Screen and orange tape should slip out as a whole
      询问修复机器人
      添加评论
    8. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 8 中的图像 1,1
      • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
      询问修复机器人
      添加评论
    9. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 9 中的图像 1,1
      • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
      询问修复机器人
      添加评论
    10. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 10 中的图像 1,1
      • Gently lift the corner of the motherboard out
      • Everything should come out as one component free of the casing
      询问修复机器人
      添加评论
    11. Ivation IVWPDC20Y Flash Bulb Replacement: 步骤 11 中的图像 1,1
      • Remove the soldering on the three wires holding the flash bulb
      • The wires are different colors: red, white, and black
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Wendy Jones
于02/06/16注册
225 声望
创作了2篇指南
团队
USF Tampa, Team 6-6, Eyestone Spring 2016 USF Tampa, Team 6-6, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G6
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 514
