跳转到主内容
加入维修社区 - 创建账户
Interface Terminal Rubber Caps
你所需要的
    • Remove the battery from the camera before beginning.
    • If you want to remove the remains of the rubber straps that once held the I/F terminal caps, do it before disassembly. They will disappear into the depths of the camera body once you remove the left cover.
    • To remove the remains of a rubber strap, pull it out as far as possible using tweezers, a needle or a small flat-tip srew driver. Then grab it from the side with small needle nose pliers. Twist the pliers to wrap the end of the strap around the pliers and pull it out.
    • Working this way instead of just pulling straight out allows you to apply more force while reducing the risk of tearing off the rubber.
    询问修复机器人
    添加评论
  1. Interface Terminal Rubber Caps, Remove the grip rubber cover: 步骤 2 中的图像 1,1
    • You will need to pry off the grip rubber to get at the screws underneath. Use your fingernails or a spudger. Starting in the lower right corner worked best for me. You may stop once the gap around the interface terminal cover is visible (green line).
    • Cut along the gap through any residue of the adhesive film.
    询问修复机器人
    添加评论
  2. Interface Terminal Rubber Caps, Removing the interface terminal cover: 步骤 3 中的图像 1,2 Interface Terminal Rubber Caps, Removing the interface terminal cover: 步骤 3 中的图像 2,2
    • Unscrew the four #6 Torx screws that were hidden under the grip rubber.
    • Pry off the cover, starting at the cut-out near the strap holder.
    询问修复机器人
    添加评论
  3. Interface Terminal Rubber Caps, Inserting the interface terminal caps: 步骤 4 中的图像 1,1
    • Fully insert the replacements caps into the cover. Then put the cover back on the camera body while holding the caps in place and at the same time making sure that the straps go into the right openings in the body (red boxes).
    询问修复机器人
    添加评论
结论
  • Screw the interface terminal cover to the camera body. Do not overtighten the screws.
  • Replacing the grip rubber is left as an exercise to the reader. If you are lucky, the original adhesive film will still work.
取消:我没有完成这个指南。
IMessedItUp
于05/08/25注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 58
总计 349
