简介
The lens unit is usually damaged when the camera is dropped on the ground or experiences some other kind of impact. If the lens unit does not move when you turn the camera on, it will need to be replaced. If the lens is cracked, it will need to be replaced. All you need for this guide is a Phillips 00 screwdriver, a Phillips 000 screwdriver, and your new lens unit from Fujifilm. As long as the camera is turned off and the battery is removed, there are no safety risks involved. To protect your new lens, always put on the strap when using the camera, and keep it in a case when you are not using it.
你所需要的
The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
Face the front side of the camera towards you. To locate the left side turn the left side of the camera towards you.
Take out the four screws, sized 4.75 mm, with the Phillips #000 screwdriver.
Remove the silver casing from the top of the camera. It is loosely clipped in and should come off easily.
Using a thin spudger, remove the chrome plastic cover from which the film is ejected. It is clipped onto the main body of the camera, and should come off with a sharp pull.
Using a thin spudger, pry off the silver casing from the bottom of the camera.
9等其他人完成本指南。
