跳转到主内容
加入维修社区 - 创建账户
Insignia NS-CLOPP2 Screen Replacement
你所需要的
    1. Insignia NS-CLOPP2 Screen Replacement, Screen: 步骤 1 中的图像 1,1
      • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
      询问修复机器人
      添加评论
    2. Insignia NS-CLOPP2 Screen Replacement: 步骤 2 中的图像 1,1
      • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
      询问修复机器人
      添加评论
    3. Insignia NS-CLOPP2 Screen Replacement: 步骤 3 中的图像 1,1
      • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
      询问修复机器人
      添加评论
    4. Insignia NS-CLOPP2 Screen Replacement: 步骤 4 中的图像 1,1
      • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
      • To reassemble your device, follow these instructions in reverse order.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Marist, Team 1-1, Laflen Spring 2015 Marist, Team 1-1, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G1
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 36
总计 578
