跳转到主内容
加入维修社区 - 创建账户
Insignia Flex 8 Screen Replacement
你所需要的
    1. Insignia Flex 8 Screen Replacement, Circuit Board: 步骤 1 中的图像 1,1
      • Turn off the power to your tablet to avoid injury.
      • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
      • Hold down the power button for five seconds until the tablet powers down.
      询问修复机器人
      添加评论
    2. Insignia Flex 8 Screen Replacement: 步骤 2 中的图像 1,2 Insignia Flex 8 Screen Replacement: 步骤 2 中的图像 2,2
      • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • You may need to use a spudger to initially create separation between the screen and the casing.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      询问修复机器人
      添加评论
    3. Insignia Flex 8 Screen Replacement: 步骤 3 中的图像 1,2 Insignia Flex 8 Screen Replacement: 步骤 3 中的图像 2,2
      • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
      添加评论
    4. Insignia Flex 8 Screen Replacement: 步骤 4 中的图像 1,3 Insignia Flex 8 Screen Replacement: 步骤 4 中的图像 2,3 Insignia Flex 8 Screen Replacement: 步骤 4 中的图像 3,3
      • To remove the camera ribbon cable, lift the flap using a spudger.
      • Pull the ribbon directly back to release it.
      询问修复机器人
      添加评论
    5. Insignia Flex 8 Screen Replacement: 步骤 5 中的图像 1,3 Insignia Flex 8 Screen Replacement: 步骤 5 中的图像 2,3 Insignia Flex 8 Screen Replacement: 步骤 5 中的图像 3,3
      • Remove the second ribbon cable by prying up the black flap using a spudger.
      • Pull the ribbon cable horizontally directly away from the battery.
      询问修复机器人
      添加评论
    6. Insignia Flex 8 Screen Replacement: 步骤 6 中的图像 1,3 Insignia Flex 8 Screen Replacement: 步骤 6 中的图像 2,3 Insignia Flex 8 Screen Replacement: 步骤 6 中的图像 3,3
      • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
      • Pull the ribbon horizontally directly away from the battery.
      询问修复机器人
      添加评论
    7. Insignia Flex 8 Screen Replacement: 步骤 7 中的图像 1,2 Insignia Flex 8 Screen Replacement: 步骤 7 中的图像 2,2
      • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
      询问修复机器人
      添加评论
    8. Insignia Flex 8 Screen Replacement: 步骤 8 中的图像 1,2 Insignia Flex 8 Screen Replacement: 步骤 8 中的图像 2,2
      • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
      • Lift up the circuit board.
      询问修复机器人
      添加评论
    9. Insignia Flex 8 Screen Replacement: 步骤 9 中的图像 1,1
      • Unscrew the final two screws that were underneath the circuit board.
      • These screws are near the charging port and USB adapter.
      • These screws are also 3.75mm and can be interchanged with the second set of screws only.
      询问修复机器人
      添加评论
    10. Insignia Flex 8 Screen Replacement: 步骤 10 中的图像 1,1
      • Lift the circuit board and black internal mounting piece away from the screen.
      • Set the circuit board aside.
      • Be careful of the soldered antenna as you separate the pieces.
      • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
      添加评论
    1. Insignia Flex 8 Screen Replacement, Screen: 步骤 11 中的图像 1,1
      • Slide the spudger in between the silver screen and the black border
      询问修复机器人
      添加评论
    2. Insignia Flex 8 Screen Replacement: 步骤 12 中的图像 1,1
      • Pry up the LCD display and lift it away from the plastic screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Colorado Springs, Team 5-5, Panko Spring 2015 Colorado Springs, Team 5-5, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G5
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 43
总计 8,673
