跳转到主内容
加入维修社区 - 创建账户
InFocus X2 Lamp Replacement
你所需要的
    1. InFocus X2 Lamp Replacement, Open the Lamp Door: 步骤 1 中的图像 1,3 InFocus X2 Lamp Replacement, Open the Lamp Door: 步骤 1 中的图像 2,3 InFocus X2 Lamp Replacement, Open the Lamp Door: 步骤 1 中的图像 3,3
      • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
      • Insert the Jimmy into one of the two notches on the lamp door's top edge.
      • Then use light force on the Jimmy to pry the latch away from the door.
      • If necessary, insert the Jimmy into the second latch and separate it from the projector.
      • Remove the door away from the projector by hand.
      询问修复机器人
      添加评论
    2. InFocus X2 Lamp Replacement, Disconnect the Lamp: 步骤 2 中的图像 1,3 InFocus X2 Lamp Replacement, Disconnect the Lamp: 步骤 2 中的图像 2,3 InFocus X2 Lamp Replacement, Disconnect the Lamp: 步骤 2 中的图像 3,3
      • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
      • Then pull the plug away from the projector.
      询问修复机器人
      添加评论
    3. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: 步骤 3 中的图像 1,3 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: 步骤 3 中的图像 2,3 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: 步骤 3 中的图像 3,3
      • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
      • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
      询问修复机器人
      添加评论
    4. InFocus X2 Lamp Replacement, Remove the Old Lamp: 步骤 4 中的图像 1,1
      • Pull on the bottom plastic tab and remove the lamp by hand.
      询问修复机器人
      添加评论
    5. InFocus X2 Lamp Replacement, Insert the New Lamp: 步骤 5 中的图像 1,1
      • Insert the replacement lamp into the projector.
      询问修复机器人
      添加评论
结论
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
取消:我没有完成这个指南。
附加文件
团队
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G3
3 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 28
总计 1,177
