简介
Replace the motherboard if experiencing sound and power problems.
For this project you may need a can of compressed air to clean the insides of the projector. You may also want safety goggles.
你所需要的
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
Remove the white tab connected to the light bulb.
