跳转到主内容
加入维修社区 - 创建账户
InFocus Screenplay 4805 Lens Replacement
你所需要的
  1. InFocus Screenplay 4805 Lens Replacement, Top Panel: 步骤 1 中的图像 1,3 InFocus Screenplay 4805 Lens Replacement, Top Panel: 步骤 1 中的图像 2,3 InFocus Screenplay 4805 Lens Replacement, Top Panel: 步骤 1 中的图像 3,3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
    询问修复机器人
    添加评论
  2. InFocus Screenplay 4805 Lens Replacement: 步骤 2 中的图像 1,2 InFocus Screenplay 4805 Lens Replacement: 步骤 2 中的图像 2,2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
    询问修复机器人
    添加评论
  3. InFocus Screenplay 4805 Lens Replacement: 步骤 3 中的图像 1,3 InFocus Screenplay 4805 Lens Replacement: 步骤 3 中的图像 2,3 InFocus Screenplay 4805 Lens Replacement: 步骤 3 中的图像 3,3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
    询问修复机器人
    添加评论
  4. InFocus Screenplay 4805 Lens Replacement: 步骤 4 中的图像 1,1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
    添加评论
  5. InFocus Screenplay 4805 Lens Replacement: 步骤 5 中的图像 1,1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
    询问修复机器人
    添加评论
  6. InFocus Screenplay 4805 Lens Replacement, Lens: 步骤 6 中的图像 1,3 InFocus Screenplay 4805 Lens Replacement, Lens: 步骤 6 中的图像 2,3 InFocus Screenplay 4805 Lens Replacement, Lens: 步骤 6 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
    • Gently pull out the lens.
    询问修复机器人
    添加评论
结论
To reassemble the device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 922
