跳转到主内容
加入维修社区 - 创建账户
InFocus Remote Motherboard Replacement
你所需要的
    1. InFocus Remote Motherboard Replacement, Front Cover: 步骤 1 中的图像 1,2 InFocus Remote Motherboard Replacement, Front Cover: 步骤 1 中的图像 2,2
      • Use your finger to press the tab on the battery cover.
      • Lift the cover up and out.
      询问修复机器人
      添加评论
    2. InFocus Remote Motherboard Replacement: 步骤 2 中的图像 1,2 InFocus Remote Motherboard Replacement: 步骤 2 中的图像 2,2
      • Use your finger to lift the two AA batteries up and out of the remote.
      询问修复机器人
      添加评论
    3. InFocus Remote Motherboard Replacement: 步骤 3 中的图像 1,1
      • Remove the three 9mm Phillips #00 screws located on the backside of the remote.
      询问修复机器人
      添加评论
    4. InFocus Remote Motherboard Replacement: 步骤 4 中的图像 1,2 InFocus Remote Motherboard Replacement: 步骤 4 中的图像 2,2
      • Insert a plastic opening tool into the seam between the black top cover and silver base at the bottom edge of the remote.
      • Carefully pry the top cover up and away from the base.
      询问修复机器人
      添加评论
    5. InFocus Remote Motherboard Replacement: 步骤 5 中的图像 1,3 InFocus Remote Motherboard Replacement: 步骤 5 中的图像 2,3 InFocus Remote Motherboard Replacement: 步骤 5 中的图像 3,3
      • Insert an opening pick into the seam on side of the remote, even with the InFocus Label.
      • Slide the opening pick along the side of the remote, moving towards the buttons.
      • There is a plastic tab that holds the covers to the base, located even with the Source button. Push the pick through with a bit more force here to disconnect the cover.
      询问修复机器人
      添加评论
    6. InFocus Remote Motherboard Replacement: 步骤 6 中的图像 1,3 InFocus Remote Motherboard Replacement: 步骤 6 中的图像 2,3 InFocus Remote Motherboard Replacement: 步骤 6 中的图像 3,3
      • Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose.
      询问修复机器人
      添加评论
    7. InFocus Remote Motherboard Replacement: 步骤 7 中的图像 1,2 InFocus Remote Motherboard Replacement: 步骤 7 中的图像 2,2
      • Firmly grasp the cover and lift it away from the remote.
      询问修复机器人
      添加评论
    1. InFocus Remote Motherboard Replacement, Button Pad: 步骤 8 中的图像 1,2 InFocus Remote Motherboard Replacement, Button Pad: 步骤 8 中的图像 2,2
      • Lift the button pad up and out of the remote.
      询问修复机器人
      添加评论
    1. InFocus Remote Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 InFocus Remote Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
      • Lift the motherboard up and out of the silver base.
      • There are two springs attached to the bottom of the motherboard that can get stuck in the base. Wiggle the board as you pull it up and out to release it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Paige Reisman
于04/07/14注册
24,175 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 29
总计 709
