跳转到主内容
加入维修社区 - 创建账户
InFocus LP540 Projector Speakers Replacement
你所需要的
    1. InFocus LP540 Projector Speakers Replacement, Speakers: 步骤 1 中的图像 1,3 InFocus LP540 Projector Speakers Replacement, Speakers: 步骤 1 中的图像 2,3 InFocus LP540 Projector Speakers Replacement, Speakers: 步骤 1 中的图像 3,3
      • Flip the projector right-side up and turn it so the backports face you.
      • Remove the 7mm metallic hex screws using the screwdriver.
      • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
      询问修复机器人
      添加评论
    2. InFocus LP540 Projector Speakers Replacement: 步骤 2 中的图像 1,2 InFocus LP540 Projector Speakers Replacement: 步骤 2 中的图像 2,2
      • Remove the two 77mm screws that are located nearest to the back panel ports using a T10 Torx screwdriver.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver.
      • Flip the projector back over.
      • Cautiously lift the main lid to avoid ripping the electrical strips.
      询问修复机器人
      添加评论
    3. InFocus LP540 Projector Speakers Replacement: 步骤 3 中的图像 1,2 InFocus LP540 Projector Speakers Replacement: 步骤 3 中的图像 2,2
      • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      询问修复机器人
      添加评论
    4. InFocus LP540 Projector Speakers Replacement: 步骤 4 中的图像 1,3 InFocus LP540 Projector Speakers Replacement: 步骤 4 中的图像 2,3 InFocus LP540 Projector Speakers Replacement: 步骤 4 中的图像 3,3
      • Place the top shell of the projector down.
      • Remove the speaker wires from the white tabs.
      • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws.
      • Carefully lift the speakers to remove them.
      询问修复机器人
      添加评论
结论
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
取消:我没有完成这个指南。
团队
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G17
6 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 904
