跳转到主内容
加入维修社区 - 创建账户
InFocus LP540 Projector Main Fans Replacement
你所需要的
    1. InFocus LP540 Projector Main Fans Replacement, Main Board: 步骤 1 中的图像 1,3 InFocus LP540 Projector Main Fans Replacement, Main Board: 步骤 1 中的图像 2,3 InFocus LP540 Projector Main Fans Replacement, Main Board: 步骤 1 中的图像 3,3
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      询问修复机器人
      添加评论
    2. InFocus LP540 Projector Main Fans Replacement: 步骤 2 中的图像 1,2 InFocus LP540 Projector Main Fans Replacement: 步骤 2 中的图像 2,2
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      询问修复机器人
      添加评论
    3. InFocus LP540 Projector Main Fans Replacement: 步骤 3 中的图像 1,3 InFocus LP540 Projector Main Fans Replacement: 步骤 3 中的图像 2,3 InFocus LP540 Projector Main Fans Replacement: 步骤 3 中的图像 3,3
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      询问修复机器人
      添加评论
    4. InFocus LP540 Projector Main Fans Replacement: 步骤 4 中的图像 1,2 InFocus LP540 Projector Main Fans Replacement: 步骤 4 中的图像 2,2
      • Hold down the release tabs to remove the cables from the white tabs.
      询问修复机器人
      添加评论
    5. InFocus LP540 Projector Main Fans Replacement: 步骤 5 中的图像 1,3 InFocus LP540 Projector Main Fans Replacement: 步骤 5 中的图像 2,3 InFocus LP540 Projector Main Fans Replacement: 步骤 5 中的图像 3,3
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      询问修复机器人
      添加评论
    6. InFocus LP540 Projector Main Fans Replacement: 步骤 6 中的图像 1,3 InFocus LP540 Projector Main Fans Replacement: 步骤 6 中的图像 2,3 InFocus LP540 Projector Main Fans Replacement: 步骤 6 中的图像 3,3
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      询问修复机器人
      添加评论
    1. InFocus LP540 Projector Main Fans Replacement, Main Fans: 步骤 7 中的图像 1,2 InFocus LP540 Projector Main Fans Replacement, Main Fans: 步骤 7 中的图像 2,2
      • Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G17
6 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 1,770
