当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
And they are fixed!
即将完成!
终点
4等其他人完成本指南。
