跳转到主内容
In-Ear Headphone Control and Mic Block Disassembly
你所需要的
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: 步骤 1 中的图像 1,1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: 步骤 2 中的图像 1,1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: 步骤 3 中的图像 1,2 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: 步骤 3 中的图像 2,2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: 步骤 4 中的图像 1,1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: 步骤 5 中的图像 1,1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
结论
Your headphones should now be working!
5等其他人完成本指南。
Alexander
于09/10/18注册
296 声望
撰写一个指南
2指南评论
Thanks a lot this worked perfectly thank you very much
MD Ratul - 回复
Very good lesson. Thanks a lot...
PK Chatterjee - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 41
过去 30 天: 184
总计 17,320
