跳转到主内容
加入维修社区 - 创建账户
IdeaPad L340-15API RAM Replacement
你所需要的
  1. IdeaPad L340-15API RAM Replacement, Optical Drive: 步骤 1 中的图像 1,2 IdeaPad L340-15API RAM Replacement, Optical Drive: 步骤 1 中的图像 2,2
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    询问修复机器人
    添加评论
  2. IdeaPad L340-15API RAM Replacement: 步骤 2 中的图像 1,2 IdeaPad L340-15API RAM Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    询问修复机器人
    添加评论
  3. IdeaPad L340-15API RAM Replacement: 步骤 3 中的图像 1,2 IdeaPad L340-15API RAM Replacement: 步骤 3 中的图像 2,2
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    询问修复机器人
    添加评论
  4. IdeaPad L340-15API RAM Replacement, Battery: 步骤 4 中的图像 1,2 IdeaPad L340-15API RAM Replacement, Battery: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    询问修复机器人
    添加评论
  5. IdeaPad L340-15API RAM Replacement: 步骤 5 中的图像 1,3 IdeaPad L340-15API RAM Replacement: 步骤 5 中的图像 2,3 IdeaPad L340-15API RAM Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    询问修复机器人
    添加评论
  6. IdeaPad L340-15API RAM Replacement: 步骤 6 中的图像 1,2 IdeaPad L340-15API RAM Replacement: 步骤 6 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    询问修复机器人
    添加评论
  7. IdeaPad L340-15API RAM Replacement: 步骤 7 中的图像 1,3 IdeaPad L340-15API RAM Replacement: 步骤 7 中的图像 2,3 IdeaPad L340-15API RAM Replacement: 步骤 7 中的图像 3,3
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    询问修复机器人
    添加评论
  8. IdeaPad L340-15API RAM Replacement: 步骤 8 中的图像 1,1
    • Remove the battery from the laptop.
    询问修复机器人
    添加评论
  9. IdeaPad L340-15API RAM Replacement, RAM: 步骤 9 中的图像 1,3 IdeaPad L340-15API RAM Replacement, RAM: 步骤 9 中的图像 2,3 IdeaPad L340-15API RAM Replacement, RAM: 步骤 9 中的图像 3,3
    • Lift the metal cover next to the heat sink to reveal the RAM.
    询问修复机器人
    添加评论
  10. IdeaPad L340-15API RAM Replacement: 步骤 10 中的图像 1,3 IdeaPad L340-15API RAM Replacement: 步骤 10 中的图像 2,3 IdeaPad L340-15API RAM Replacement: 步骤 10 中的图像 3,3
    • Using your fingers or a spudger, spread the clips away from the RAM module.
    • Be careful not to pull too hard and damage the metal arms.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, insert it at about the same angle until it fits securely, then gently press it downward until the clips click into place.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jasmyn
于10/16/25注册
205 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 的会员
UMASSD-BOWMAN-F25S2G5
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 33
总计 204
