跳转到主内容
加入维修社区 - 创建账户
ILVE Microwave Replacement Bulb Replacement
你所需要的
    1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: 步骤 1 中的图像 1,1
      • Remove the brown plug.
      • The screw attaching the microwave is below
      询问修复机器人
      添加评论
    2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: 步骤 2 中的图像 1,2 ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: 步骤 2 中的图像 2,2
      • Remove the cross point screws from the outer case back
      • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
      • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
      询问修复机器人
      添加评论
    3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: 步骤 3 中的图像 1,1
      • The socket is on top right side of the microwave
      • Remove the plugs
      • Bend up the metal clips, and pull out the socket
      询问修复机器人
      添加评论
    4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: 步骤 4 中的图像 1,2 ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: 步骤 4 中的图像 2,2
      • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
      • The glue goes all the way down the thread so remove as much as you can see.
      • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
      询问修复机器人
      添加评论
    5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: 步骤 5 中的图像 1,1
      • When you re assemble the outer case make sure the tabs on the front go either side of the front.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Martin Hampton
于02/13/16注册
1,350 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 56
总计 4,499
