跳转到主内容
加入维修社区 - 创建账户
IBM Thinkpad T60 Wireless Card Replacement
你所需要的
  1. IBM Thinkpad T60 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    询问修复机器人
    添加评论
  2. IBM Thinkpad T60 Wireless Card Replacement: 步骤 2 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    询问修复机器人
    添加评论
  3. IBM Thinkpad T60 Wireless Card Replacement, Palm Rest: 步骤 3 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement, Palm Rest: 步骤 3 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    添加评论
  4. IBM Thinkpad T60 Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
    询问修复机器人
    添加评论
  5. IBM Thinkpad T60 Wireless Card Replacement: 步骤 5 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
    • Detach the connector by pulling upwards on the white tab.
    添加评论
  6. IBM Thinkpad T60 Wireless Card Replacement, Keyboard: 步骤 6 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement, Keyboard: 步骤 6 中的图像 2,2
    • Turn the Thinkpad over so you can see the bottom.
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
    询问修复机器人
    添加评论
  7. IBM Thinkpad T60 Wireless Card Replacement: 步骤 7 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement: 步骤 7 中的图像 2,2
    • First, flip the laptop back over. Next, use your fingers to pry the keyboard upwards slightly.
    • Lift the keyboard until you are able to see the wire connection
    添加评论
  8. IBM Thinkpad T60 Wireless Card Replacement: 步骤 8 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement: 步骤 8 中的图像 2,2
    • Pull upwards on the connector to disconnect the keyboard.
    • The keyboard is now disconnected.
    询问修复机器人
    添加评论
  9. IBM Thinkpad T60 Wireless Card Replacement, Wireless Card: 步骤 9 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement, Wireless Card: 步骤 9 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the two 10.5 mm screws.
    询问修复机器人
    添加评论
  10. IBM Thinkpad T60 Wireless Card Replacement: 步骤 10 中的图像 1,2 IBM Thinkpad T60 Wireless Card Replacement: 步骤 10 中的图像 2,2
    • Disconnect the two connectors by pulling upwards on the base of the grey and black cables.
    询问修复机器人
    添加评论
  11. IBM Thinkpad T60 Wireless Card Replacement: 步骤 11 中的图像 1,1
    • Grasp the sides of the card and pull perpendicular to the slot.
    • The wireless card is now disconnected.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G9
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 55
总计 6,792
