跳转到主内容
加入维修社区 - 创建账户
IBM Thinkpad T60 LCD Screen Replacement
你所需要的
  1. IBM Thinkpad T60 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    询问修复机器人
    添加评论
  2. IBM Thinkpad T60 LCD Screen Replacement: 步骤 2 中的图像 1,2 IBM Thinkpad T60 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    询问修复机器人
    添加评论
  3. IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 2,3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 3,3
    • Open the laptop so that the screen is facing you.
    • Use a plastic opening tool to pry off the eight plastic screw covers around the display.
    • Note that there are screw covers on the sides (two on the left and one on the right).
    添加评论
  4. IBM Thinkpad T60 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove the eight 3.25 mm screws uncapped from the previous step.
    询问修复机器人
    添加评论
  5. IBM Thinkpad T60 LCD Screen Replacement: 步骤 5 中的图像 1,2 IBM Thinkpad T60 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Carefully pry the plastic border away from the screen using the plastic opening tool.
    • Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
    添加评论
  6. IBM Thinkpad T60 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Use your fingers to pry the screen out of its housing far enough to gain access to the ribbon cables and small screws holding the screen in place.
    询问修复机器人
    添加评论
  7. IBM Thinkpad T60 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • At the top of the screen, detach the small white clip by pulling it towards you with your finger.
    询问修复机器人
    添加评论
  8. IBM Thinkpad T60 LCD Screen Replacement: 步骤 8 中的图像 1,2 IBM Thinkpad T60 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the 4 mm screw.
    询问修复机器人
    添加评论
  9. IBM Thinkpad T60 LCD Screen Replacement: 步骤 9 中的图像 1,2 IBM Thinkpad T60 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
    • The other two screws are in the same position on the opposite side of the display.
    询问修复机器人
    添加评论
  10. IBM Thinkpad T60 LCD Screen Replacement: 步骤 10 中的图像 1,2 IBM Thinkpad T60 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • The screen should be free to move now. Let the display rest on the keyboard with the screen facing down.
    • Peel the tape off to expose the LCD connection.
    询问修复机器人
    添加评论
  11. IBM Thinkpad T60 LCD Screen Replacement: 步骤 11 中的图像 1,2 IBM Thinkpad T60 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Turn the inverter over to expose the white clip.
    • Squeeze and pull the wires with your fingers to detach the white clip.
    询问修复机器人
    添加评论
  12. IBM Thinkpad T60 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Disconnect the video cable by pulling the grey flat wire. Now the screen is completely separate from the ThinkPad.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
团队
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G9
4 名成员
创作了16篇指南
1指南评论
Thanks for the info! ☼
Stck Flw - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 67
总计 13,806
