跳转到主内容
加入维修社区 - 创建账户
IBM ThinkPad t43 RAM Replacement
你所需要的
    1. IBM ThinkPad t43 RAM Replacement, RAM: 步骤 1 中的图像 1,3 IBM ThinkPad t43 RAM Replacement, RAM: 步骤 1 中的图像 2,3 IBM ThinkPad t43 RAM Replacement, RAM: 步骤 1 中的图像 3,3
      • To remove the cover, you will need to take out the single screw.
      • Unscrew until the cover comes off
      • Lift the cover from the edge and pull off
      • If the cover doesn't come right up and you have felt that you have unscrewed it, you can lift the cover and the screw will come off with it.
      询问修复机器人
      添加评论
    2. IBM ThinkPad t43 RAM Replacement: 步骤 2 中的图像 1,3 IBM ThinkPad t43 RAM Replacement: 步骤 2 中的图像 2,3 IBM ThinkPad t43 RAM Replacement: 步骤 2 中的图像 3,3
      • Place your hands on the clips and push on them outward until the RAM pops out
      询问修复机器人
      添加评论
    3. IBM ThinkPad t43 RAM Replacement: 步骤 3 中的图像 1,2 IBM ThinkPad t43 RAM Replacement: 步骤 3 中的图像 2,2
      • Place hands on the RAM and pull towards yourself
      • For replacement, follow these steps in reverse order
      • Make sure that when you put in the ram that the short side is on the right
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
aLiX pIeRRe
于03/19/18注册
884 声望
创作了5篇指南
团队
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 的会员
UMASSD-BERNIER-S18S6G4
4 名成员
创作了35篇指南
1指南评论
There are two (2) SODIM slots on the T43 - this shows the easiest slot to access. There is a second SODIM slot underneath the keyboard. You will need to remove the palm rest and keyboard to access the second SODIM slot. This is the SODIM slot that comes populated with the 512MB SODIM.
Note you can add a 2GB SODIM in one slot with the 512MB SODIM in the other for a maximum of 2.5GB.
IrishMASMS - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 36
总计 1,837
