跳转到主内容
加入维修社区 - 创建账户
IBM ThinkPad T41 RAM Replacement
你所需要的
  1. IBM ThinkPad T41 RAM Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    添加评论
  2. IBM ThinkPad T41 RAM Replacement: 步骤 2 中的图像 1,1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    添加评论
  3. IBM ThinkPad T41 RAM Replacement: 步骤 3 中的图像 1,1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    询问修复机器人
    添加评论
  4. IBM ThinkPad T41 RAM Replacement: 步骤 4 中的图像 1,1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    询问修复机器人
    添加评论
  5. IBM ThinkPad T41 RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
    询问修复机器人
    添加评论
  6. IBM ThinkPad T41 RAM Replacement: 步骤 6 中的图像 1,1
    • Lift out the RAM chip.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G8
4 名成员
创作了29篇指南
1指南评论
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
Gary Thurman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 50
总计 8,191
