跳转到主内容
加入维修社区 - 创建账户
IBM ThinkPad T30 Hard Drive Replacement
你所需要的
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 IBM ThinkPad T30 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 IBM ThinkPad T30 Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
    询问修复机器人
    添加评论
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  3. IBM ThinkPad T30 Hard Drive Replacement: 步骤 3 中的图像 1,3 IBM ThinkPad T30 Hard Drive Replacement: 步骤 3 中的图像 2,3 IBM ThinkPad T30 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
    询问修复机器人
    添加评论
  4. IBM ThinkPad T30 Hard Drive Replacement: 步骤 4 中的图像 1,2 IBM ThinkPad T30 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
    询问修复机器人
    添加评论
  5. IBM ThinkPad T30 Hard Drive Replacement: 步骤 5 中的图像 1,2 IBM ThinkPad T30 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
    询问修复机器人
    添加评论
结论
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G20
3 名成员
创作了17篇指南
1指南评论
good description and photos..thanks :]
David - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 94
总计 20,707
