跳转到主内容
Huawei P9 Lite Front Camera Replacement
你所需要的
  1. Huawei P9 Lite Front Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei P9 Lite Front Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Front Camera Replacement: 步骤 2 中的图像 1,1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Front Camera Replacement: 步骤 3 中的图像 1,1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Front Camera Replacement, Motherboard Shield: 步骤 4 中的图像 1,1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Front Camera Replacement: 步骤 5 中的图像 1,2 Huawei P9 Lite Front Camera Replacement: 步骤 5 中的图像 2,2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  6. Huawei P9 Lite Front Camera Replacement, Motherboard: 步骤 6 中的图像 1,2 Huawei P9 Lite Front Camera Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the SIM card tray.
  7. Huawei P9 Lite Front Camera Replacement: 步骤 7 中的图像 1,3 Huawei P9 Lite Front Camera Replacement: 步骤 7 中的图像 2,3 Huawei P9 Lite Front Camera Replacement: 步骤 7 中的图像 3,3
    • Disconnect the motherboard flex, the battery flex and the antenna cable.
  8. Huawei P9 Lite Front Camera Replacement: 步骤 8 中的图像 1,2 Huawei P9 Lite Front Camera Replacement: 步骤 8 中的图像 2,2
    • Disconnect the display flex and the power and volume button cable.
  9. Huawei P9 Lite Front Camera Replacement: 步骤 9 中的图像 1,2 Huawei P9 Lite Front Camera Replacement: 步骤 9 中的图像 2,2
    • Unplug the rear camera and the headphone jack.
  10. Huawei P9 Lite Front Camera Replacement: 步骤 10 中的图像 1,2 Huawei P9 Lite Front Camera Replacement: 步骤 10 中的图像 2,2
    • Take the camera and the headphone jack out of their recesses.
  11. Huawei P9 Lite Front Camera Replacement: 步骤 11 中的图像 1,3 Huawei P9 Lite Front Camera Replacement: 步骤 11 中的图像 2,3 Huawei P9 Lite Front Camera Replacement: 步骤 11 中的图像 3,3
    • Use a spudger to lift the motherboard carefully.
    • Remove the motherboard assembly.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
  12. Huawei P9 Lite Front Camera Replacement, Front Camera: 步骤 12 中的图像 1,2 Huawei P9 Lite Front Camera Replacement, Front Camera: 步骤 12 中的图像 2,2
    • Disconnect the front camera flex from the motherboard.
    • Flip the motherboard over and thread the flex cable through the opening and take the camera away.
结论
5等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,781
