跳转到主内容
Huawei P8 Lite Motherboard Replacement
你所需要的
  1. Huawei P8 Lite Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei P8 Lite Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 1,3 Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 2,3 Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 3,3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Motherboard Replacement, Loudspeaker: 步骤 3 中的图像 1,1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Huawei P8 Lite Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Huawei P8 Lite Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the three Phillips #00 screws that hold the metal plate in place.
    • Remove the metal plate with a tweezer.
    • Unplug the battery flex connector with a spudger.
  7. Huawei P8 Lite Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the two Torx T5 screws.
    • If there is a tamper evident sticker over your screws remove them to properly seat your driver.
    • Remove the five Phillips #00 screws.
  8. Huawei P8 Lite Motherboard Replacement: 步骤 8 中的图像 1,2 Huawei P8 Lite Motherboard Replacement: 步骤 8 中的图像 2,2
    • Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
    • Then remove the top cover.
  9. Huawei P8 Lite Motherboard Replacement: 步骤 9 中的图像 1,3 Huawei P8 Lite Motherboard Replacement: 步骤 9 中的图像 2,3 Huawei P8 Lite Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove the SIM card and SD card trays.
    • Disconnect the three plug connectors and one ZIF connector.
    • Unlock the ZIF connector by lifting the small black plastic lever.
  10. Huawei P8 Lite Motherboard Replacement: 步骤 10 中的图像 1,3 Huawei P8 Lite Motherboard Replacement: 步骤 10 中的图像 2,3 Huawei P8 Lite Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove the volume and power button cable.
    • Take out the motherboard by lifting the bottom part first.
    • Pay attention to the cables, so they don't rip when staying stuck to the motherboard.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If this thermal pad broke or is too dried out you might want to replace it with a new one.
结论
To reassemble your device, follow these instructions in reverse order and apply adhesive where necessary.
9等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,802 声望
创作了188篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,083篇指南
一条评论
My p8 lite is not connecting to mobile networks unless im in town onyl whats the prob
Mhofu Powers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 52
总计 10,282
