跳转到主内容
Huawei P10 Lite Headphone Jack Replacement
你所需要的
  1. Huawei P10 Lite Headphone Jack Replacement, Back cover: 步骤 1 中的图像 1,3 Huawei P10 Lite Headphone Jack Replacement, Back cover: 步骤 1 中的图像 2,3 Huawei P10 Lite Headphone Jack Replacement, Back cover: 步骤 1 中的图像 3,3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Headphone Jack Replacement: 步骤 2 中的图像 1,3 Huawei P10 Lite Headphone Jack Replacement: 步骤 2 中的图像 2,3 Huawei P10 Lite Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Headphone Jack Replacement: 步骤 3 中的图像 1,2 Huawei P10 Lite Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Headphone Jack Replacement: 步骤 4 中的图像 1,2 Huawei P10 Lite Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
  5. Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: 步骤 5 中的图像 1,3 Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: 步骤 5 中的图像 2,3 Huawei P10 Lite Headphone Jack Replacement, Battery Disconnection: 步骤 5 中的图像 3,3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
  6. Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 1,2 Huawei P10 Lite Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 2,2
    • Use the flat end of a spuder to disconnect the headphone jack flex cable.
    • Altough the headphone jack is not glued to the mid frame it is a little bit tucked in its bracket. Be careful not to damage it during the removal.
    • Remove the headphone jack.
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
203,975 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 13
总计 3,359
