跳转到主内容
Huawei P10 Charging Board Replacement
你所需要的
  1. Huawei P10 Charging Board Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P10 Charging Board Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P10 Charging Board Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
    Das Honor 9 hat an der Unterkante keine Schrauben.
    Wie ist das Honor 9 zu öffnen?
    Michael Tuschek - 回复
    Vielleicht beantwortet diese Anleitung deine Frage ;)
    Tobias Isakeit -
    Hi, my P10 does not have screws, just two tiny holes. Do I push in here to unfasten? Einar, Norway
    Einar Ryvarden - 回复
    Hi Einar Ryvarden,
    in case you bought a used or refurbished phone, someone might have forgotten to put them back in. Since you have holes at the bottom edge next to the charging port this is likely. You can try to start with step 2 and see if you can lift the phone assembly (don’t forget to remove the SIM tray first). As far as I know there is no version of the regular Huawei P10 with no screws. However you there are none in the P10 lite and in the P10 plus, maybe one of the opening procedures for those phones might help you.
    Dominik Schnabelrauch -
  2. Huawei P10 Charging Board Replacement: 步骤 2 中的图像 1,3 Huawei P10 Charging Board Replacement: 步骤 2 中的图像 2,3 Huawei P10 Charging Board Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
    Hi! I cannot find a way to insert the plastic opening tool. Any suggestions on how I can create a gap to start. Everything seems quit rigid.
    Also, where will I find your reply.
    vbr/lars.skoldebring@gmail.com
    lars.skoldebring - 回复
    Hi Lars, you might want to use a suction handle to lift the display and create a small gap to insert the plastic tool. If you don’t have a suction handle you can “build” a handle with tape that you stick onto the display in a shape similar to this —> __∏__ (also you may want to edit your post and remove your email address ;) )
    Tobias Isakeit -
    Hi,
    I’m stuck at this step for about two hours… There’s nothing I can do to open the case. Tried all kinds of opening tools and a suction handle. There is no gap at all between the display and the body. How can anything be inserted into a gap that practically does not exist? Please help.
    Mark Movshovich - 回复
    Sorry to hear that. You could try and lift the display by using a suction cup and pull to create a small gap for a tool to get in.
    Tobias Isakeit -
  3. Huawei P10 Charging Board Replacement: 步骤 3 中的图像 1,2 Huawei P10 Charging Board Replacement: 步骤 3 中的图像 2,2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
    The cable is for the standby and volume buttons, not for the fingerprint sensor!
    JaL - 回复
    Thanks JaL, of course it is.
    Tobias Isakeit -
  4. Huawei P10 Charging Board Replacement, Battery disconnect: 步骤 4 中的图像 1,3 Huawei P10 Charging Board Replacement, Battery disconnect: 步骤 4 中的图像 2,3 Huawei P10 Charging Board Replacement, Battery disconnect: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Charging Board Replacement, Charging Board: 步骤 5 中的图像 1,2 Huawei P10 Charging Board Replacement, Charging Board: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  6. Huawei P10 Charging Board Replacement: 步骤 6 中的图像 1,2 Huawei P10 Charging Board Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
    Warum soll das Antennenkabel gelöst werden? M.E. schafft dieser Schritt nur ein Risiko das Antennenkabel/den Stecker zu beschädigen.
    Jan Bühler - 回复
  7. Huawei P10 Charging Board Replacement: 步骤 7 中的图像 1,2 Huawei P10 Charging Board Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
    Ist das entfernen der Kopfhörerbuchse nötig? M.E. nicht - es besteht vielleicht ein geringes Risiko, diese beim Display entfernen zu beschädigen, aber vermutlich wird man diese eher lösen als beschädigen.
    Jan Bühler - 回复
  8. Huawei P10 Charging Board Replacement: 步骤 8 中的图像 1,2 Huawei P10 Charging Board Replacement: 步骤 8 中的图像 2,2
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
    Use the correct angle when putting the (new) charging board back. At the top of the charging board it must be underneath the edge.
    Raymond - 回复
    I didn’t remove the charging board (I didn’t look precisely enough and thought I had to remove the head phone socket which I put back again as it can stay in place) and it didn’t interfer.
    Jan Bühler - 回复
    Please also include that their might be a small piece of tape over the microphone on the new PCB.
    My mic was not working "on ear" but it was working when on speaker.
    Found that small piece of tape by comparing the 2 boards, removed the tape and problem solved.
    Frederik Dewolf - 回复
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
15等其他人完成本指南。
于11/23/16注册
230,309 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,537篇指南
4条评论
Just remember to take off a tape from the microphone on a new piece. I had to open mine twice
Michal Kornacki - 回复
If you have problems on connecting the cable to the charging port, before considering replacing the charging board, try removing the dust that may be occluding the port. Use tweezers to remove the dust and try if the cable connects. Do it carefully as your could damage the pins.
Gerard Encina Llamas - 回复
Second the above comment! - If you are having trouble fully inserting the USB cable, then try remove the dust with a pair of fine tweezers.
Andrew Norwood - 回复
I recently changed the battery of my P10 but the phone always died when the brandnew battery was still at 50%. It is no battery calibration issue - over the next ten days it got worse, died at 70%, now it frequently dies at 90%. The phone only starts with charging cable plugged in, then the battery charges from 90% to 100% in roughly one hour, but the "charged" battery only lasts about an hour or less, the phone dies when it reaches 90%. Looks to me like fake charging (or rather fake uncharging?). Is someone familiar with such an issue? Was the new battery defect from store? Or is the charger defect? The phone runs fine with power cable plugged in. Can it still be the charging board? Should I try the replacement shown in this article?
Xen - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 59
总计 7,259
